Pan
6 years agoIntel HLS (19.4) - Not supported device family except Stratix 10
I always used Arria10 device, when compiling with 19.3 version and everything worked as expected. I shifted to 19.4 compiler recently, and since the shift, an error has been occurring when other dev...
- 6 years ago
I am able to compile the example design in HLS compiler v19.3 and v19.4 and could not duplicate the error as shown on your side.
It seems like the problems is cause by the device files are not installed correctly.
Could you try to reinstall the Arria 10 device files?
Pan
6 years agoHi,
here you go. Just do make intel_sim and then make intel_cosim. The testbench outputs were fine before, but I altered the code a bit and had to reverse it back for you. Now, it doesn't show me testbench outputs for simulation. Even so, it doesn't effect platform designer fail in any way.
Also, I would like to point out that compilations are much slower then it used to be in 19.3.
Again, I am not unable to upload two files at once, so I zipped it.
Thanks for your time.
