Pan
6 years agoIntel HLS (19.4) - Not supported device family except Stratix 10
I always used Arria10 device, when compiling with 19.3 version and everything worked as expected. I shifted to 19.4 compiler recently, and since the shift, an error has been occurring when other dev...
- 6 years ago
I am able to compile the example design in HLS compiler v19.3 and v19.4 and could not duplicate the error as shown on your side.
It seems like the problems is cause by the device files are not installed correctly.
Could you try to reinstall the Arria 10 device files?
MEIYAN_L_Intel
6 years agoHi,
May I know the design file for HLs compiler to compile?
Also, could you provide the command flow so that I can try it on my side for further investigate?
