Intel HLS (19.4) - Not supported device family except Stratix 10
- 6 years ago
I am able to compile the example design in HLS compiler v19.3 and v19.4 and could not duplicate the error as shown on your side.
It seems like the problems is cause by the device files are not installed correctly.
Could you try to reinstall the Arria 10 device files?
I had check the Arria 10 log file and I saw the information below:
Info: qsys-generate /home/local/xpanak04/p4base/compiler/p4hls/intel/tests/dummies/sys_launch_always_run/solution_4/intel_cosim.prj/components/foo/foo.ip --synthesis=VERILOG --output-directory=/home/local/xpanak04/p4base/compiler/p4hls/intel/tests/dummies/sys_launch_always_run/solution_4/intel_cosim.prj/components/foo/foo --family="Stratix 10" --part=Unknown
It seems like the qsys generated for Stratix 10 device but your selected device is Arria 10, hence there is a warning given that invalid device family name in input file: Arria 10.
Could you confirm the qsys-script: foo.tcl is selected the correct device?
Also, may I have the qsys-script: foo.tcl for further investigate?
