Intel HLS (19.3) - Bad implementation of memory.
- 6 years ago
I had tried to compile the code and the attached code is not able to compile.
I have added the following line to make it compile:
#include <HLS/ac_int.h>
#include <HLS/hls.h>
#define HLS_COMPONENT component
#define REG_ADDR WIDTH 64
This appears to be a regression from 19.1; when compiled using 19.1, the 40-bit and 41-bit both worked nicely. It appears that in the 40-bit case, the compiler decomposes the 40-bit store into power-of-2 stores, 8+8+8+16. A workaround is to set the type in memory to be a 64-bit ac_int.
Thanks for your time. I know the behaviour of 19.3 compilation, the fact that 19.1 compiles the right way is interesting. The workaround is obvious, but it will consume resources.
Maybe the question is more about whether this problem will be resolved in the new version of Intel HLS?
Again, thanks for your time and have a great day.
