Pan
6 years agoIntel HLS (19.3) - Bad implementation of memory.
The expected implementation should have 1 Write (2 shared stores) and 1 Read (1 load) port. But those are the implementations in different cases: REG2_DATA_WIDTH 40 - Wrong implementation. The memo...
- 6 years ago
I had tried to compile the code and the attached code is not able to compile.
I have added the following line to make it compile:
#include <HLS/ac_int.h>
#include <HLS/hls.h>
#define HLS_COMPONENT component
#define REG_ADDR WIDTH 64
This appears to be a regression from 19.1; when compiled using 19.1, the 40-bit and 41-bit both worked nicely. It appears that in the 40-bit case, the compiler decomposes the 40-bit store into power-of-2 stores, 8+8+8+16. A workaround is to set the type in memory to be a 64-bit ac_int.
Pan
6 years agoI have already uploaded component part only. But here you go with full main.cpp with testbench. The results should be:
15
30
201
101
(For some reason I cannot upload more than one file at once.)
