GTese
6 years agoIntel FPGA for Opencl
The following error was generated with sd card. How can I solve this problem? I use DE1_Soc board and OS Ubuntu 20.04.
root@socfpga:~# EXT4-fs (mmcblk0p2): error count: 14 EXT4-fs (mmcblk0p2): in...
AnilErinch_A_Intel
5 years agoHi ,
Please use the recommended versions of Linux , it looks like you were using an older version of Quartus and newer latest version of Ubuntu. If you can try using Ubuntu 18.04 or 16.04 that should actually be helpful in solving the issue. The error which you have mentioned is a Linux related error.
Thanks and Regards
Anil
- GTese5 years ago
Thanks!
After I use the Ubuntu 20.04 version error was solved.
