TxLy123
3 years agoIntel FPGA Edition SIM ERROR vopt-14408
There comes an simulation error :
Error (suppressible): (vopt-14408) Intel FPGA Edition recommended capacity is 5000 non-OEM instances.
I want to know how to solve it and make my simulation runni...
ShengN_altera
3 years agoHi,
Regarding the "vsim -suppress 14408" command, this command only suppresses the display of the error message in the transcript. Additionally, you need to specify the top-level design module you want to simulate after the vsim command. For an example:
vsim -suppress 14408 -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L maxii_ver -L rtl_work -L work half_adder_tb
Sheng
- Eric_Liu2 years ago
Thanks you Sheng, I got the same issue, but could be soloved after using your "suppress" command! It works!
