RubenPadial
Contributor
1 year agoIntel FPGA AI Sutie Inference Engine
Is there any official documentation on the DLA runtime or inference engine for managing the DLA from the ARM side? I need to develop a custom application for running inference, but so far, I’ve only ...
JohnT_Altera
1 year agoHi Ruben,
I think you might need to only provide new input of data and not changing the blob which will think that this is a new inference setting.
During the 1st run, you should have performed all the setting and during the second run onwards, you should just provide the input data.
- RubenPadial1 year ago
Contributor
Hello @JohnT_Intel,
Same behaviour.
I changed to create the blobs before the loop and only filling them in the loop:// Create blobs only once before the loop using Blob_t = std::vector<std::map<std::string, Blob::Ptr>>; std::vector<std::pair<Blob_t, Blob_t>> ioBlobs = vectorMapWithIndex<std::pair<Blob_t, Blob_t>>( exeNetworks, [&](ExecutableNetwork* const& exeNetwork, uint32_t index) mutable { Blob_t inputBlobs; Blob_t outputBlobs; ConstInputsDataMap inputInfo = exeNetwork->GetInputsInfo(); ConstOutputsDataMap outputInfo = exeNetwork->GetOutputsInfo(); for (uint32_t batch = 0; batch < num_batches; batch++) { std::map<std::string, Blob::Ptr> outputBlobsMap; for (auto& item : outputInfo) { auto& precision = item.second->getTensorDesc().getPrecision(); if (precision != Precision::FP32) { THROW_IE_EXCEPTION << "Output blob creation only supports FP32 precision. Instead got: " + precision; } auto outputBlob = make_shared_blob<PrecisionTrait<Precision::FP32>::value_type>(item.second->getTensorDesc()); outputBlob->allocate(); outputBlobsMap[item.first] = (outputBlob); } std::map<std::string, Blob::Ptr> inputBlobsMap; for (auto& item : inputInfo) { Blob::Ptr inputBlob = nullptr; auto& precision = item.second->getTensorDesc().getPrecision(); if (precision == Precision::FP32) { inputBlob = make_shared_blob<PrecisionTrait<Precision::FP32>::value_type>(item.second->getTensorDesc()); } else if (precision == Precision::U8) { inputBlob = make_shared_blob<PrecisionTrait<Precision::U8>::value_type>(item.second->getTensorDesc()); } else { THROW_IE_EXCEPTION << "Input blob creation only supports FP32 and U8 precision. Instead got: " + precision; } inputBlob->allocate(); inputBlobsMap[item.first] = (inputBlob); } inputBlobs.push_back(inputBlobsMap); outputBlobs.push_back(outputBlobsMap); } return std::make_pair(inputBlobs, outputBlobs); } ); std::cout << "Blobs initialized once before the loop.\n"; while (1) { ... // Fill blobs with new input values (DO NOT re-create them) for (size_t i = 0; i < exeNetworks.size(); i++) { slog::info << "Filling input blobs for network ( " << topology_names[i] << " )" << slog::endl; fillBlobs(inputs, ioBlobs[i].first); // Only fill the existing blobs } ... }Error: dlia_infer_request.cpp:53 Number of inference requests exceed the maximum number of inference requests supported per instance
