Intel FPGA AI suite accuracy drop
Do you incluse the custom Intel FPGA AI Suite Library? https://www.intel.com/content/www/us/en/docs/programmable/768972/2023-3/inputs-dla-compiler-command-options.html
May I know what is the design you use on FPGA that is able to obtain same accuracy?
- RubenPadial2 years ago
Contributor
Hello @JohnT_Intel,
I think the option you suggest is --plugin-file, which is set by default to =$COREDLA_ROOT/bin/plugins.xml. It is the same file I'm refering to.
The FPGA design that is able to give the 98.89% of accuracy follows the same approach that Intel FPGA AI Suite. It is currently under study and I cannot make public more deatils. It is a research project. but I can give you more details by email if are really interested in.
Contributor
Please, find in the following link the complete TF model, IR model and Compiled Graph https://consigna.ugr.es/download.php?files_ids=63731
