Intel Acceleration Stack for D5005 install
When I tried to download from the address, https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/intel-fpga-pac-d5005/getting-started.html ,in the D5005 installation manual, I found that the address was redirected elsewhere. Now how can I download Intel Acceleration Stack for D5005?
- JohnT_Altera
You can get the download from https://www.intel.com/content/www/us/en/software-kit/665814/intel-fpga-pac-d5005-acceleration-stacks-v2-0-1.html?wapkw=d5005
- jimbook_
thanks for your help, but there is a new problem. oneAPI toolkit didn't support to centos7, but this Download only support to centos7. Is there some way to make D5005 install in centos8 or oneAPI old version can support to centos7?
- JohnT_Altera
May I know which oneAPI version are you installing? Are you able to use oneAPI 2019? If not which Acceleration Stack version are you using?
- jimbook_
I use d5005_pac_ias_2_0_1_pv_rte_installer.tar.
And I successfully built oneAPI development environment for D5005 last year, using oneAPI toolkit 2022.2.
- jimbook_
- jimbook_
how can I get the oneAPI toolkit 2022.2?
- JohnT_Altera
It looks like there is no longer older version of OneAPI for download. Currently there is no workaround for this until we are releasing https://ofs.github.io/ (Open FPGA Stack) with OneAPI support.
- jimbook_
So when will it be supported. My graduation project relied on the sycl scheme.
- JohnT_Altera
You may use OPAE 2.3.0 which can work on CentOS 8 with DCP 2.0.1. You can get the installation guide from https://opae.github.io/2.3.0/docs/install_guide/installation_guide.html.
- jimbook_
thanks for your help, it's realy helpful for me. Thank you very mach.
- JohnT_Altera
May I know if you have any other queries?
