Intel的PAC卡在开发过程中,使用remote signal tap进行时,在本地执行如下命令报错。
Hi JohnT,
finally I got it works now.now signaltap can remotely capture data now.
the reason is that
after I put 2 assignments into afu.qsf
set_global_assignment -name ENABLE_SIGNALTAP ON
set_global_assignment -name USE_SIGNALTAP_FILE "../../hw/par/A10/stp_basic.stp"
those above 2 assignmetn supposed be done by extra_tcl-0_stp.tcl
but if you check the path in extra_tcl-0_stp.tcl you will find the path is wrong
set_global_assignment -name USE_SIGNALTAP_FILE ../hw/par/A10/stp_basic.stp.
the correct one is
the wrong one made stp file can not be included during the compilation, that is why stp always reported Can't find the instance. Download a design with SRAM Object File containing this instance.
that original extra_tcl-0_stp.tcl is provided by vendor, I have not changed it. that is root cause.
thanks for your help.
I think many other customer would duplicate same issue, if they follow the instruction from page 35 in chapter 6 AFU in-system debug of AFU Developer’s Guide for Intel FPGA Programmable Acceleration Card.
thanks all your help.
Best regard
Jim
