Install intel-fpga-addon-for-oneapi on Ubuntu 20.04
Hi and thanks in advance for your help!
I'm trying to install intel-fpga-addon-for-oneapi-base-kit-for-a10gx-s10sx-linux on Ubuntu 20.04. The oneAPI base toolkit is already installed and working. However, this is what I get:
root@cedro:~/intel/install-oneAPI/intel-fpga-addon-for-oneapi-base-kit-for-a10gx-s10sx-linux/l_intel_fpga_dpcpp-a10gx-s10sx-2021.1.1# sudo ./setup.sh ------------------------------------------------------------------------------- - Welcome to the Intel(R) FPGA Add-on for oneAPI Base Toolkit for PAC A10 and S10 Board 2021.1.1 installation ------------------------------------------------------------------------------- Press Enter to continue Intel(R) FPGA Add-on for oneAPI Base Toolkit for PAC A10 and S10 Board is only supported on RHEL 7 or Ubuntu 18.04, you're currently on DISTRIB_ID=Ubuntu. Do you want to continue to install the software? (Y/n): Y QUARTUS PRIME AND INTEL FPGA IP LICENSE AGREEMENT, VERSION 19.2 ... ... Do you accept this license? (y/n): y Enter the oneAPI root path [default: /opt/intel/oneapi/]: You already have board support package "intel_a10gx_pac" installation at /opt/intel/oneapi//intelfpgadpcpp/2021.1.1/board/intel_a10gx_pac, do you want to continue to install to this location? (Choosing 'y' will remove all the existing files there) (Y/n): n Enter the oneAPI root path [default: /opt/intel/oneapi/]: You already have board support package "intel_a10gx_pac" installation at /opt/intel/oneapi//intelfpgadpcpp/2021.1.1/board/intel_a10gx_pac, do you want to continue to install to this location? (Choosing 'y' will remove all the existing files there) (Y/n): n Enter the oneAPI root path [default: /opt/intel/oneapi/]: You already have board support package "intel_a10gx_pac" installation at /opt/intel/oneapi//intelfpgadpcpp/2021.1.1/board/intel_a10gx_pac, do you want to continue to install to this location? (Choosing 'y' will remove all the existing files there) (Y/n): Y You already have board support package "intel_s10sx_pac" installation at /opt/intel/oneapi//intelfpgadpcpp/2021.1.1/board/intel_s10sx_pac, do you want to continue to install to this location? (Choosing 'y' will remove all the existing files there) (Y/n): Y install_dir=/opt/intel/oneapi Removing /opt/intel/oneapi/intelfpgadpcpp/2021.1.1/board/intel_a10gx_pac ... Removing /opt/intel/oneapi/intelfpgadpcpp/2021.1.1/board/intel_s10sx_pac ... Do you wish to install prerequisites? Note: Installing will require administrative access (sudo) and network access. (Y/n): Y ------------------------------------------------------------------------------- - Install Pre-requisite packages ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- - Installing board support package intel_a10gx_pac ------------------------------------------------------------------------------- >>> Running cmd: tar -xzf /root/intel/install-oneAPI/intel-fpga-addon-for-oneapi-base-kit-for-a10gx-s10sx-linux/l_intel_fpga_dpcpp-a10gx-s10sx-2021.1.1/components/intel_a10gx_pac.tar.gz -C /opt/intel/oneapi/intelfpgadpcpp/2021.1.1/board ------------------------------------------------------------------------------- - Installing board support package intel_s10sx_pac ------------------------------------------------------------------------------- >>> Running cmd: tar -xzf /root/intel/install-oneAPI/intel-fpga-addon-for-oneapi-base-kit-for-a10gx-s10sx-linux/l_intel_fpga_dpcpp-a10gx-s10sx-2021.1.1/components/intel_s10sx_pac.tar.gz -C /opt/intel/oneapi/intelfpgadpcpp/2021.1.1/board ------------------------------------------------------------------------------- - Installing OPAE PACSign package for RedHat/CentOS ... ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- - Installing OPAE PACSign ... ------------------------------------------------------------------------------- >>> Running cmd: sudo yum -y --setopt=skip_missing_names_on_install=False install --nogpgcheck opae.pac_sign-1.0.3-1.x86_64.rpm sudo: yum: command not found Command: "sudo yum -y --setopt=skip_missing_names_on_install=False install --nogpgcheck opae.pac_sign-1.0.3-1.x86_64.rpm" exited with error code: 1 root@cedro:~/intel/install-oneAPI/intel-fpga-addon-for-oneapi-base-kit-for-a10gx-s10sx-linux/l_intel_fpga_dpcpp-a10gx-s10sx-2021.1.1#
Thanks!
- Quant_Geek
See the following thread below. The package from Intel assumes a much older kernel and thus will not work in Ubuntu 20.04, but you can try the following:
https://github.com/OPAE/opae-sdk/issues/1583
QG
- GouthamK_Intel
Thanks for reaching out to us!
As your issue is related to FPGA, we have a dedicated forum for FPGA related issues.
We are redirecting this thread to FPGA Forum for faster response.
Have a Good day.
Thanks & Regards
Goutham
- longgnol
I would like to ask where I can download "intel-fpga-addon-for-oneapi-base-kit-for-a10gx-s10sx-linux"?
Thanks!
