QPham9
7 years agoIncremental compile - System integrator failed
Hello, I encountered an error "System Integrator FAILED" when I tried to run an incremental compile (step 3 in section 7.24 of the programming guide for intel FPGA for OpenCL, see link below) after ...
QPham9
6 years agoSo I got pass the error "Can't copy Board template files..."
The incremental compile finished w/o issue for the example project. So it's not the "task" attribute that caused the issue.
I am still trying to re-create the "system integrator failed" issue using the example project. If you have any suggestion, please let me know.
