QPham9
7 years agoIncremental compile - System integrator failed
Hello, I encountered an error "System Integrator FAILED" when I tried to run an incremental compile (step 3 in section 7.24 of the programming guide for intel FPGA for OpenCL, see link below) after ...
QPham9
7 years agoHi Mylee,
The compiler is aoc version 19.2.0 build 57 pro edition on Windows 10 Pro.
Because of the work I am doing, I can't provide the code.
If you have a sample code that you know it works, I am happy to compile it to see if It's my code or the tool that caused the issue.
Q
