QPham9
7 years agoIncremental compile - System integrator failed
Hello, I encountered an error "System Integrator FAILED" when I tried to run an incremental compile (step 3 in section 7.24 of the programming guide for intel FPGA for OpenCL, see link below) after ...
MEIYAN_L_Intel
7 years agoHi,
May I know the information as below:
- OpenCL compiler/ BSP version used
- OS used
Can you provide the hots code file and kernel code file attached here to further investigate?
