IDV Tool
According to the operation steps indicated by the 576087 document, the following two problems occur during the use of IDV Tool, and the attachment is the problem screenshot.
1. Just collect the signals of the first 4 roads. The signals in the latter road are not collected or collected. There are only some peak signals;
2. The voltage level information and actual measurement values in the collected 4 -channel signal are not in line with the actual measurement value, and the setting value does not meet.
- Farabi_Altera
We need to know what device are you measuring? Do you know the part number?
regards,
Farabi
- Farabi_Altera
What is the FPGA part number you are using? For example, Stratix 10, Agilex, MAX10 etc.
We need this information to help you.
regards,
Farabi
- Farabi_Altera
As there is no response from your side, I am closing this case.
regards,
Farabi
