ArthurRatz
6 years agoI cannot build and run my code for Intel PAC platform in Intel DevCloud.
Hi Everyone, For a few last days long, I'm no longer able to compile and run my code in Intel DevCloud for oneAPI projects. The attempts to compile and run my code typically end up with the followi...
- 6 years ago
Thanks for reaching out.
You can compile and run the oneAPI samples on FPGA platform in Intel Devcloud.Kindly make sure you use the below commands to compile and run the samples.
build_fpga_emu.sh
source /opt/intel/inteloneapi/setvars.sh make fpga_emu -f Makefile.fpga
run_fpga_emu.sh
make run_emu -f Makefile.fpga
Try this and let us know the updates.
ArthurRatz
6 years agoHi, I'm using Intel DevCloud for Intel oneAPI projects. Previously I could compile and run my CL/SYCL program on Intel PAC Platform, but now I experience these difficulties. Also, as I've inspected the following issue, the quartus_fit process crashes when an amount of reserved virtual memory exceeds 16GiB ~ 16384 MB for this process.
Looking forward for this issue resolution as soon as possible :)
Arthur,
