I can build a pac_a10 design for profiling on devcloud, and compile the host code containing a clGetProfileInfoIntelFPGA() call, but when I run it I get the error listed in the Details.
I did pull that example, and I can run it using vtune on a gen9 node of devcloud.
It also warns about accessing the /proc/kallsyms file, so apparently that is normal.
I still have the problem that when I try to run my vector-add executable with vtune on a devcloud fpga_run node I get an error, but when I run it without vtune it works fine. Is there an example somewhere of how to used vtune with an FPGA board?
It seems like it could not be accessed to used in FPGA and there only example to use vtune to fpga via command line in link: https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/command-line-interface/generating-command-line-reports.html
If more question for vtune on fpga support, you may need to post a new forum for better support on this.
