I can build a pac_a10 design for profiling on devcloud, and compile the host code containing a clGetProfileInfoIntelFPGA() call, but when I run it I get the error listed in the Details.
According to the link: https://github.com/intel/BaseKit-code-samples/tree/master/VtuneProfiler/matrix_multiply_vtune, the .dpcpp file is compiled. Could you try on this?
- DHawv6 years ago
I did pull that example, and I can run it using vtune on a gen9 node of devcloud.
It also warns about accessing the /proc/kallsyms file, so apparently that is normal.
I still have the problem that when I try to run my vector-add executable with vtune on a devcloud fpga_run node I get an error, but when I run it without vtune it works fine. Is there an example somewhere of how to used vtune with an FPGA board?
- MEIYAN_L_Intel6 years ago
It seems like it could not be accessed to used in FPGA and there only example to use vtune to fpga via command line in link: https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/command-line-interface/generating-command-line-reports.html
If more question for vtune on fpga support, you may need to post a new forum for better support on this.
