DHawv
6 years agoI can build a pac_a10 design for profiling on devcloud, and compile the host code containing a clGetProfileInfoIntelFPGA() call, but when I run it I get the error listed in the Details.
Error message running bin/host from the command line: Error: Unable to find function name clGetProfileInfoIntelFPGA in board library /glob/development-tools/versions/oneapi/beta05/inteloneapi/compil...
MEIYAN_L_Intel
6 years agoHi,
I am checking the information internally with developer.
By using 'devcloud_login', you could be able to choose the login node with device. May I know which login node you are trying to login to node s001-n138 for Intel PAC A10 device?
