DHawv
6 years agoI can build a pac_a10 design for profiling on devcloud, and compile the host code containing a clGetProfileInfoIntelFPGA() call, but when I run it I get the error listed in the Details.
Error message running bin/host from the command line: Error: Unable to find function name clGetProfileInfoIntelFPGA in board library /glob/development-tools/versions/oneapi/beta05/inteloneapi/compil...
DHawv
6 years agoThe solution was to compile the host code on an fpga_compile node rather than on the fpga_runtime node.
I had the opposite problem with fast emulation, where it was necessary to compile the code on the fpga_runtime node for the program to be able to find the emulation platform at run time (on either type of node).
It would be nice to be able to compile host code for emulation or profiling on either type of node.
