User1582192733150209
6 years agoHow to update The FIM and BMC firmware for 2 INTEL PAC on same server
Hello Sir/Madam, Our server has 2 same Intel PAC Arria10 inserted. When I check the cards using fpgainfo fme and found one of the BMC is not showing correct as below [root@fig01 a10_gx_pac_ias_1_2...
JohnT_Altera
6 years agoHi,
From the "fpgainfo fme", the FIM is updated but not the BMC. So you will need to make sure that the BMC is also updated to make it work correctly.
