User1582192733150209
6 years agoHow to update The FIM and BMC firmware for 2 INTEL PAC on same server
Hello Sir/Madam, Our server has 2 same Intel PAC Arria10 inserted. When I check the cards using fpgainfo fme and found one of the BMC is not showing correct as below [root@fig01 a10_gx_pac_ias_1_2...
6 years agoDear JohnT,
thanks for your suggestion, which is very useful.
just like you mentioned ,there is only 1 USB blaster connected to one of them, but I do not know how to match the physical card with PCIE bus number?
Is there any diagnosing program I can use to know which PCIE Pac CARD has USB connection, because server is in remote location, from phisical view I can not match PCIE BDF with specific card.
I have tried 2 diagnosing program nlb_3 and DMA_AFU for both these 2 cards, totally 4 test cases worked correctly, I guess that is because that examples running use PCIE to download gbs, and does not involve usb-JTAG.
thanks
Jim
