User1582192733150209
6 years agoHow to update The FIM and BMC firmware for 2 INTEL PAC on same server
Hello Sir/Madam, Our server has 2 same Intel PAC Arria10 inserted. When I check the cards using fpgainfo fme and found one of the BMC is not showing correct as below [root@fig01 a10_gx_pac_ias_1_2...
JohnT_Altera
6 years agoHi,
Based on the message provided, you are connecting the USB-Blaster to only 1 of the device. Could you confirm that the blaster is connected to the board with older BMC? If no, please change the blaster to that board.
