How to solve the problem during updating the FIM and BMC firmware
I have installed Intel Acceleration Stack for Runtime v1.2.1 and OPAE package successfully. But when I want to update the FIM and BMC firmware, I met the following problem.
I run the command
sudo fpgaotsu /usr/share/opae/a10*/fpgaotsu/base/otsu-09C4.json
then the error occurred.
[2021-12-16 15:39:12,632] [INFO ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:08:00.0 is not secure. [2021-12-16 15:39:12,638] [WARNING ] [MainThread] Update starting. Please do not interrupt. [2021-12-16 15:39:12,638] [INFO ] [0000:08:00.0] Updating Intel PAC with Intel Arria 10 GX FPGA : 0000:08:00.0 [2021-12-16 15:39:12,638] [INFO ] [0000:08:00.0] Erasing flash@0x7fd0000 for 196608 bytes [2021-12-16 15:39:12,838] [INFO ] [0000:08:00.0] Writing flash@0x7ff0000 for 104 bytes (RushCreek_Release_key_blk2) (100%) [████████████████████] [104/104 bytes][Time:0:00:00.001080] [2021-12-16 15:39:12,840] [INFO ] [0000:08:00.0] Reading flash@0x7ff0000 for 104 bytes for verification (100%) [████████████████████] [104/104 bytes][Time:0:00:00.013918] [2021-12-16 15:39:12,854] [INFO ] [0000:08:00.0] Verified flash@0x7ff0000 for 104 bytes (RushCreek_Release_key_blk2) [2021-12-16 15:39:12,854] [INFO ] [0000:08:00.0] Erasing flash@0x1800000 for 41943040 bytes [2021-12-16 15:39:28,459] [ERROR ] [0000:08:00.0] [Errno 110] Connection timed out Traceback (most recent call last): File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaotsu.py", line 509, in process_flash_item self.erase(flash, mtd_dev) File "/usr/lib/python2.7/dist-packages/opae/admin/tools/fpgaotsu.py", line 317, in erase (erase_end + 1) - erase_start) File "/usr/lib/python2.7/dist-packages/opae/admin/utils/mtd.py", line 149, in erase fcntl.ioctl(fp.fileno(), self.IOCTL_MTD_MEMERASE, iodata) IOError: [Errno 110] Connection timed out [2021-12-16 15:39:28,480] [INFO ] [MainThread] Total time: 0:00:15.841772 [2021-12-16 15:39:28,480] [ERROR ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:08:00.0: [Errno 110] Connection timed out [2021-12-16 15:39:28,480] [ERROR ] [MainThread] One-Time Secure Update failed
This is OPAE and FIM information
ii opae-a10-gx-pac-fpgaotsu-base 1.2.1 all Intel PAC one-time-update ii opae-a10-gx-pac-super-rsu-base 1.2.1 all Intel PAC super-rsu ii opae-ase 1.1.2 amd64 OPAE AFU Simulation Environment ii opae-devel 1.1.2 amd64 OPAE headers, sample source, and documentation ii opae-intel-fpga-driver 2.0.3 all DKMS-enabled Intel FPGA driver source code. ii opae-libs 1.1.2 amd64 OPAE runtime ii opae-tools 1.1.2 amd64 OPAE base tool binaries ii opae-tools-extra 1.1.2 amd64 OPAE extra tool binaries ii python-opae.admin 1.0.2 all OPAE Administration ii python3-opae.pac-sign 1.0.3-1 amd64 opae.pac_sign provides Python classes for interfacing withOP
Board Management Controller, microcontroller FW version 26889 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEE00000 PCIe s:b:d:f : 0000:08:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x123000200000185 Bitstream Version : 1.2.3 Pr Interface Id : 69528db6-eb31-577a-8c36-68f9faa081f6 Boot Page : user
Can anyone help me?
- EricMunYew_C_Intel
Have you attached a USB cable to Arria 10 PAC during FIM and BMC upgrade.
You can refer to page 39 below for upgrading FIM and BMC.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qs-ias-v1-2-1.pdf
Since this thread had been answered, we shall close this thread. If you still need further assistance, you are welcome to post a response within 15days or open a new thread, some one will be right with you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
