Wei-Chih
4 years agoHow to obtain the valuse of get_local_id(0), get_group(0) and get_local_range(0) in single_task
Hi support team
I am modifying the code for running FPGA hardware on oneapi devcloud. The original sample code is for GPU/CPU which uses parallel_for lambda function for kernel, but for FPGA optim...
BoonBengT_Altera
Moderator
4 years agoHi @Wei-Chih,
As every application are coded to execute differently, hence it would be best to go through the optimization report or profiler to which will gives more accurate insights on what to change and you can refer to the optimization guide.
With no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread and no longer monitor this thread.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
