How to modify makefile by calling FPGA and GPU?
Hi ,
Can you share the complete source file and make file which you have changed.
Thanks and Regards
Anil
- HYB5 years ago
vector-add-buffers.cpp
#include <CL/sycl.hpp>
#include <array>
#include <iostream>
#if FPGA || FPGA_EMULATOR
#include <CL/sycl/INTEL/fpga_extensions.hpp>
#endif
using namespace sycl;
// Create an exception handler for asynchronous SYCL exceptions
static auto exception_handler = [](sycl::exception_list e_list) {
for (std::exception_ptr const &e : e_list) {
try {
std::rethrow_exception(e);
catch (std::exception const &e) {
#if _DEBUG
std::cout << "Failure" << std::endl;
#endif
std::terminate();
int main() {
try {
queue q1(INTEL::fpga_selector, exception_handler);
queue q2(default_selector, exception_handler);
// Print out the device information used for the kernel code.
std::cout << "Running on device1: "
<< q1.get_device().get_info<info::device::name>() << "\n";
std::cout << "Running on device2: "
<< q2.get_device().get_info<info::device::name>() << "\n";
} catch (exception const &e) {
std::cout << "An exception is caught for vector add.\n";
std::terminate();
return 0;
Makefile.fpga
CXX := dpcpp
CXXFLAGS = -O2 -g -std=c++17
SRC := src/vector-add-buffers.cpp
.PHONY: fpga_emu run_emu fpga_emu_usm run_emu_usm clean
fpga_emu: vector-add-buffers.fpga_emu
hw: vector-add-buffers.fpga
report: vector-add-buffers_report.a
vector-add-buffers.fpga_emu: $(SRC)
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -DFPGA_EMULATOR=1
a.o: $(SRC)
$(CXX) $(CXXFLAGS) -fintelfpga -c $^ -o $@ -DFPGA=1
vector-add-buffers.fpga: a.o
$(CXX) $(CXXFLAGS) -fintelfpga $^ -o $@ -Xshardware
run_emu: vector-add-buffers.fpga_emu
./vector-add-buffers.fpga_emu
clean:
rm -rf *.o *.d *.out *.mon *.emu *.aocr *.aoco *.prj *.fpga_emu *.fpga_emu_buffers vector-add-buffers.fpga vector-add-usm.fpga *.a
