zjinf
7 years agoHow to maping add and multiplication calculation to FPGA logic element, not DSP unit in AOC environment
How to maping add and multiplication calculation to FPGA logic element, not DSP unit in AOC environment ! In my project(most are added and multiplication calculation ) , the DSP unit used is more th...
CheepinC_altera
7 years agoHi Jinfu,
As I understand it, you have some inquiries related to implementing some of your add and multiplication function in FPGA logic instead of hard DSP block. Just wonder if you are coding the function using Verilog HDL or if you are using any specific IP? Also just would like to check with you which device and Quartus version that you are using?
Take CV device as example, the following are ways that you can try to see if it helps:
1. If you are using IP, for your information, you may try with LPM_MULT and then select "Use logic elements" for implementation
2. If you are using your own Verilog HDL, you can try to specific "multstyle = dsp/logic" attribute to choose between soft logic or DSP block. You may refer to Insert Template -> Verilog HDL -> Synthesis Attributes -> multstyle Attribute for further details.
Chee Pin
zjinf
7 years agohi cpchan
thanks for your help!
my coding is opencl, the kernel is *.cl file , not verilog HDL or any IP, the aocl compiler translate to DSP or logic by itself !
maybe any "compiler command" can help to do this when DSP over-utilization in theory , but i don't know the "compiler command"
