How to define separate bankbits on each memory replicate?
Hi Dimitris ,
Hope you are staying safe
you can double the number of ports in the replica if you double pump the component.
So it will give you 4 ports per replicate.
You also have the flexibility to use the hls_memory and hls_bankwidth attributes to change the number of banks and bank bits.
Please refer to section 5
Component Memories (Memory Attributes)
of the following documents and try to come up with the best possible solution you can.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/mnl-hls-reference.pdf
Then we can analyze the reports and can work on it further.
Thanks and Regards
Anil
We do not receive any response from you to the previous question/reply/answer that I have provided.
Please post a response in the next 15 days to allow me to continue to support you.
After 15 days, this thread will be transitioned to community support.
The community users will be able to help you with your follow-up questions
