SAbde7
7 years agoHow do I use the Avalon MM slave template to connect a PCIE DMA to FIFOs inside my custom logic?
I am trying to transfer data from a PC to a FIFO on the FPGA. I am using PCIE DMA for the transfer. That data is then used in calculations, and the results are stored in another FIFO that then has to...
Nathan_R_Intel
Contributor
7 years agoHie,
Could you provide more details as following so I can check if you could directly use Intel's IP generated reference design to transfer data
i. Which FPGA device
ii. Quartus version used
Nathan
SAbde7
7 years agoI have solved the issue by writing a custom component with a custom avalon slave.
