How do I integrate my RTL design with OpenCL kernel synthesis results into one AFU (one gbs file)?
An OpenCL kernel compiled with the OpenCL compiler will directly connect to the interfaces defined in the OpenCL BSP. If your RTL needs access to FPGA I/O, then you should add that to the OpenCL BSP and recreate the BSP, which will be a difficult task. If, however, your RTL does not need to access FPGA I/O, you can convert it to an RTL library as describe in Intel FPGA SDK for OpenCL's guides, and then directly instantiate that library in an OpenCL kernel. The last option is to convert your OpenCL kernel to an HLS kernel and compile it using Intel's HLS compiler into an HDL module and then integrate it with your existing RTL module and other necessary IP cores through Qsys.
First of all, thank you!
I need connect my RTL to IO. I need to connect it to a 10G MAC.
Also I need DDR too.
Do you know a guide that explains how to do this?
Maybe reverse? Maybe there is a way to insert the OpenCL compiler result into the AFU environment that I created as a FPGA developer.
