SAbde7
6 years agoHow can I use a specific compilation/exploration point from DSEII for my actual project?
After running DSEII, I don't know how to manipulate the results I get. How can I apply one of the compilations to my project to generate an .sof file, or how do I save the exploration points to use t...
sstrell
6 years agoThey should get saved in your project directory, I believe (output_files directory perhaps). Are you not seeing them?
#iwork4intel
SAbde7
6 years agoMy DSE is set to "save all results". I found this in my project directory
At this point I had already ran DSE with 6 seeds + base several time, changing a paramter in the project every time. I would have asumed that this folder is the collection of all compilations that were named DSE_1. However, the "dse" folder only contains "dse1", so if the previous assumption is correct, then I don't know where the compilation that were not called dse_1 went. In addition, this folder only contains one quar file, so I don't know which one of the many project versions in this folder get restored by it.
