maxhu's avatar
maxhu
3 years ago
How can I port RTL module into oneAPI FPGA programming ?
Hi there, I have been using oneAPI for FPGA programming for a while. I am now trying to port my well-defined RTL module into my oneAPI implementation.
I do read and understand the specification documents provided in oneAPI websites also the openCL SDK development. However, one of these have pointed a very clear way to interact with RTL module using oneAPI.
I am successfully runing a combinational vector-add sample myself, but have no idea how to interact with the sythesized modules from oneAPI with clock driven capability and Avalon-ST interface.
Have anyone done such a tryout before ?
Best.
  • hareesh's avatar
    hareesh
    i will check and will update to you
    • maxhu's avatar
      maxhu
      Hi Hareesh,
      Did you get anything back from your colleagues ? I tried implemented a simple Avalon Stream interface based on the oneAPI documents and also the given example. I modified the original combinational logic example into a sequential version. However, I still lack some more details:
      1. I dont konw the exact specification of the required Avalon-Stream interface for porting RTL into oneAPI environment. Is there any worked example or detailed illustration that I can check ?
      2. I am able to get the simulation waveform using ModelSim, however, I cannot read the Machine Generated signals... Is there any more convinient way to debug my RTL module ?
      3. To my understanding and based on the given documents from oneAPI websites, I wrote the RTL code for porting a simple vector add RTL module into oneAPI, which may not meet the requirements of Avalon Stream interface. The code and XML file are attached below.
      `timescale 1 ps / 1 ps
      module lib_rtl (
        input   clock,
        input   resetn,
        input   ivalid,
        input   iready,
        output  ovalid,
        output  oready,
        input   [31:0]  datain1,
        input   [31:0]  datain2,
        output  [31:0]  dataout);
        logic [31:0] dataout_buffer, dataout_reg;
        logic ovalid_reg, oready_reg;
        assign ovalid = ovalid_reg;
        assign oready = oready_reg;
        assign dataout = (oready_reg & !iready) ? dataout_buffer : dataout_reg;
        // assign  dataout = result;
        // clock, ivalid, iready, resetn are ignored
        always @(posedge clock) begin
          // reset or non-valid input
          // all the signals are default zero
          if(!resetn || !ivalid) begin
            dataout_reg <= 0;
            dataout_buffer <= 0;
            oready_reg <= 0;
            ovalid_reg <= 0;
          end
          else if (ivalid) begin
            ovalid_reg <= 1;
            oready_reg <= 1;
            dataout_reg <= datain1 + datain2;
          end
        end
        always@(*) begin
          $display("ivalid = %d iready = %d  dataout_reg = %d\n", ivalid, iready, dataout_reg);
          $display("datain1 = %d data2 = %d dataout %d\n", datain1, datain1, dataout);
        end
      endmodule
      <RTL_SPEC>
        <FUNCTION name="RtlByteswap" module="lib_rtl">
          <ATTRIBUTES>
            <IS_STALL_FREE value="yes"/>
            <IS_FIXED_LATENCY value="yes"/>
            <EXPECTED_LATENCY value="0"/>
            <CAPACITY value="0"/>
            <HAS_SIDE_EFFECTS value="no"/>
            <ALLOW_MERGING value="yes"/>
          </ATTRIBUTES>
          <INTERFACE>
            <AVALON port="clock" type="clock"/>
            <AVALON port="resetn" type="resetn"/>
            <AVALON port="ivalid" type="ivalid"/>
            <AVALON port="iready" type="iready"/>
            <AVALON port="ovalid" type="ovalid"/>
            <AVALON port="oready" type="oready"/>
            <INPUT  port="datain1" width="32"/>
            <INPUT  port="datain2" width="32"/>
            <OUTPUT port="dataout" width="32"/>
          </INTERFACE>
          <REQUIREMENTS>
            <FILE name="lib_rtl.v" />
          </REQUIREMENTS>
        </FUNCTION>
      </RTL_SPEC>
      I also read some materials from Intel OpenCL SDK for FPGA docs, there are some documents telling how to mix RTL and OpenCL together, but I am not sure whether they are accurate reference docs. Please give me more details for further exploration.
      Thanks for your kind reply and help.
      Best,
      Jiajun.
    • maxhu's avatar
      maxhu
      Hi hareesh,
      Sorry for late reply. I have solved the problem that I encountered. The real question thta I want to ask is that, is there a way to illustrate the implementation of Avalon-Stream interface under backpressure modules ? Although I have solved the problem, I am still confused about the Avalon-Stream interface specified by the Intel OpenCL SDK website.
      I do read some examples about OpenCL SDK programming, one for simple combinational circuit and another one for a very complicated extern memory interaction example. The true is that, combinational is too simple but interacting with external memory is too much complicated. Is there a mid-point example that I can explore ?
      Best,
      Jiajun.
  • hareesh's avatar
    hareesh
