maxhu
3 years agoHow can I port RTL module into oneAPI FPGA programming ?
Hi there, I have been using oneAPI for FPGA programming for a while. I am now trying to port my well-defined RTL module into my oneAPI implementation. I do read and understand the specification docu...
hareesh
3 years agoHi,
any update about your issue?
maxhu
3 years agoHi hareesh,
Sorry for late reply. I have solved the problem that I encountered. The real question thta I want to ask is that, is there a way to illustrate the implementation of Avalon-Stream interface under backpressure modules ? Although I have solved the problem, I am still confused about the Avalon-Stream interface specified by the Intel OpenCL SDK website.
I do read some examples about OpenCL SDK programming, one for simple combinational circuit and another one for a very complicated extern memory interaction example. The true is that, combinational is too simple but interacting with external memory is too much complicated. Is there a mid-point example that I can explore ?
Best,
Jiajun.
