ishikawa
5 years agoHow can I implement the 'counter sample' in FPGA (DE10-Standard)?
I was able to high-level synthesize the counter in the hls example file, but I don't know how to implement it in the FPGA from there.
I have several files generated by high-level synthesis, which f...
KennyT_altera
5 years agoHi,
You may look into https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls.pdf -> 8. Integrating your IP into a System . Make sure you take a look into the previous secssion in case you missed out some steps.
You may also look into https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf for I++ example
