dreamqin68
5 years agoHLS Main Optimizer FAILED. How can I debug it?
command :
i++ design.cc -v -march=5CSEBA6U23I7 --debug-log --simulator none --quartus-compile -o test-fpga
Error:
make: *** [test-fpga] Error 1
It’s just t...
AnilErinch_A_Intel
5 years agoHi ,
If you cannot share the code , you can provide a pseudo code with giving the HLS specific calls and number of iterations of loops etc.
If you have Iterations you can try reducing the number and see the results. Also
Please make sure that you follow the instructions related to Quartus requirements while targeting Cyclone® V with HLS compiler.
1.3. Installing the Intel HLS Compiler Pro Edition for Cyclone® V Device Support
Thanks and Regards
Anil
