HLS Main Optimizer FAILED. How can I debug it?
command :
i++ design.cc -v -march=5CSEBA6U23I7 --debug-log --simulator none --quartus-compile -o test-fpga
Error:
make: *** [test-fpga] Error 1
It’s just that the feedback failed in the end, but it didn’t give me any other tips. How can I debug it?
Other information:
- OS version: Redhat 6
- HLS Compiler version: 18.1
- Logfile: Only provide the command
Thanks in Advance!
- AnilErinch_A_Intel
Hi ,
If you cannot share the code , you can provide a pseudo code with giving the HLS specific calls and number of iterations of loops etc.
If you have Iterations you can try reducing the number and see the results. Also
Please make sure that you follow the instructions related to Quartus requirements while targeting Cyclone® V with HLS compiler.
1.3. Installing the Intel HLS Compiler Pro Edition for Cyclone® V Device Support
Thanks and Regards
Anil
- VenkateshSathar
can u attach debug.log generated after running the command??
if u want to compile quartus project, u can use quartus gui software to open and synthesize ur generated proj. From the GUI, it can provide more information.
- dreamqin68
Thanks for your advice.
There is only one line of command in debug.log, and then there is no other information.
I only know using Quartus HLS compiler to do high level synthesis. How to use Quartus GUI to do HLS?
I use Quartus Prime Lite 18.1 to connect IP and design system, but I don't know it can synthesis IP.
Are there any related tutorials or guide documents?
Thanks!
- VenkateshSathar
I am also trying hls but 19.1 version since 2wk ago. at first, i tried with linux but thing did not go well. so im running it on window now. It can run smoother. after having right experience, i ll move back to linux later. i suggest u to try a non-lite version on a virtual machine, get 30 day trial license to get it through, go through intel hls examples first, read the manual carefully.
Here something u can try now.
- check if hls support CycloneV or not
- try hls with Arria10 (all hls versions support arria10)
- run the following command# --debug-log -v -ghdl --> turn on all logging feature i++ hello.cc -v -march=Arria10 --debug-log -v -ghdl --simulator none -o test-fpga # should see a new folder test-fpga.proj. inside it, there are subfolders: components, quartus, reports, verification # synthesize component with quartus i++ hello.cc -v -march=Arria10 --debug-log -v -ghdl --quartus-compile # or u can use quartus to open project <ur project folder>\test-fpga.proj\quartus\quartus_compile.qsf
