HLS compiler in Quartus Pro Edition vs Standard Edition
Thanks you for your information. I will report this information to the developer about the feature request in OS support.
For your information, "if you have multiple versions of Visual Studio, Microsoft recommends installing
Visual Studio versions in the order in which the versions were released. For
example, install Visual Studio 2010 before installing Visual Studio 2015. For
details, see Install Visual Studio Versions Side-by-Side in the MSDN Library" as stated in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf chapter 1.4.
According to https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html, I found that the Stratix V is not support in pro edition.
Thank you, I didn't know about it
- HRZ6 years ago
Indeed Stratix V is only supported in the Standard versions, and the Quartus Prime Standard toolchain is not under active development anymore which means it will rarely get updated anymore (if at all). The Pro version is still updated frequently and this is the reason why it supports more OSes and newer Visual Studio.
