HLS Compiler 24.1 error - aocl-clang.exe - dll entry point not found
- 2 years ago
Thanks Noah. Please install Quartus 23.1lite, then add HLS as an 'upgrade', paying attention to step 3 of the Getting Started Guide. Make sure you remove/rename any version of HLS that exists in 23.1lite; I spoke with some people in engineering and the error you're seeing might appear if HLS 24.1 pro happens to pick up the libraries from HLS 23.1std.
Hello again, so I reinstalled both Quartus Prime Lite 23.1 and HLS Compiler 24.1 in a new PC, and this time it does work correctly.
So, I reckon it could have been either the OS, or the tool version - this time I made sure I installed the 2X.1 version. Perhaps last time I installed a 2X.1.1 version instead.
Thank you so much for your support, I am accepting your last message as solution to indicate that the issue is solved.
