HLS Compiler 24.1 error - aocl-clang.exe - dll entry point not found
- 2 years ago
Thanks Noah. Please install Quartus 23.1lite, then add HLS as an 'upgrade', paying attention to step 3 of the Getting Started Guide. Make sure you remove/rename any version of HLS that exists in 23.1lite; I spoke with some people in engineering and the error you're seeing might appear if HLS 24.1 pro happens to pick up the libraries from HLS 23.1std.
I'll also let you know now that HLS is deprecated, and we are encouraging users to explore its successor, the FPGA Support Package for oneAPI DPC++/C++ Compiler instead.
- NoahHuguenin2 years ago
My .dll files are attached to this message.
In any case, using the ones you provided yields the same result.
I plan on installing in a different computer soon. If that works, I will post the result in this thread.
In parallel, I am looking into oneAPI as well
