NoahHuguenin
2 years agoHLS Compiler 24.1 error - aocl-clang.exe - dll entry point not found
Good day, I recently installed HLS Compiler 24.1 together with Quartus Prime Lite 23.1std in order to do the first HLS tests. I installed Visual Studio 2017 Community and the latest version of Mic...
- 2 years ago
Thanks Noah. Please install Quartus 23.1lite, then add HLS as an 'upgrade', paying attention to step 3 of the Getting Started Guide. Make sure you remove/rename any version of HLS that exists in 23.1lite; I spoke with some people in engineering and the error you're seeing might appear if HLS 24.1 pro happens to pick up the libraries from HLS 23.1std.
whitepau_altera
Contributor
2 years agoThanks for checking. I wonder if something is wrong with your installation/installer. Can you please attach the versions of those DLLs to this case? In the meantime, I'll upload the DLLs that come from my working installation. Please copy your existing dsdk.dll, generationlib.dll, mathlib.dll and mip_common.dll to a different directory before replacing them with mine.
