High Level Synthesis (HLS) Counter Example HLS Generate testbench QSYS system FAILED
- 4 years ago
Hello again.
I couldn't work on this job for a while. After trying your recommendations, I realized that I cannot create a regular Quartus project because my machine does not run Quartus well as it is too old. When I tried the same procedure on a newer machine I was able to make HLS work.
Thanks a lot for your help.
Hi @anil007,
Noted and thanks for the details explanation, I have tried the same on my windows machine with the setup mention and are able to compile with the mention example design and generate the cosimulation for HDL execution.
On 5 files mention I have just installed the 'QuartusLiteSetup-21.1.1.850-windows.exe', followed by the cyclone device with 'cyclonev-21.1.1.850.qdz' and finally the HLSProSetup-22.2.0.94-windows.exe. (the questa and programmer comes with the quartus lite installation)
Would suggest to check on a few things as below:
- Open the Quartus lite and try to create a empty project with cycloneV as the device.
- Running the init_hls.bat to check on the setup
- If all failed, would suggest to reinstalled the quartus and HLS with on the 3 files mention
Hope that clarify
BB
