KG0001
6 years agoHi Team, I have Intel Dev cloud account (u42910) where doing the programming by using Intel oneapi (DPC ++). shall i use the same dev cloud for Intel FPGA Open CL programming. I want to try Open CL based programming for FPGA devices.
I tried to install 'Intel FPGA SDK for OpenCL' which require minimum 25GB system RAM memory to install that kind of machine don;t have. so looking alternative option to exercise Open CL programming...
KennyT_altera
6 years agohttps://github.com/intel/FPGA-Devcloud/tree/master/main/Devcloud_Access_Instructions#devcloud-access-instructions
Instead of answering "What are you trying to use the Devcloud for? ..." every time to start an interactive login to a compute node, you can type the following:
devcloud_login -I <argument options>
-----------------------------------Argument-Options-------------------------------------
A10PAC <development-stack version>
A10OAPI
S10PAC
CO
SNN <s00X-nXXX>
Type the following to simply view a list of the available nodes, to etheir specifically choose a compute node when submitting a batch job or to start an interactive login:
devcloud_login -l
