pguda1's avatar
pguda1
7 years ago
Hi guys, we got the PAC S10 board(D5005) and successfully ran the dma example on this board but we failed to add NIOS. Can please tell me how to add NIOS in PR region by using PAC card?
Hi guys, we got the PAC S10 board(D5005) and successfully ran the dma example on this board but we try to add the NIOS in dma example and run synthesis by using OPAE then synthesis failed and errors are
Alt_sld_fab_0.alt_sld_fab_0: add_instance: Can't create component type altera_sld_agent_endpoint_tieoff
Alt_sld_fab_0.alt_sld_fab_0.alt_sld_fab_0.ocpfabric.clock: ocpfabric.clock must be connected to a clock output
Error opening /home/User1/prakash/dma_afu/build_synth/build/qdb/_compiler/afu_default/_flat/18.1.2/partitioned/1/.temp/sld_fabrics/ipgen/alt_sld_fab_0/alt_sld_fab_0.ip.
1 Reply
  • Hi Prakash,
    Apologize for idle for awhile. Do you able to solve the issue? Do you need further help?
