JSell4
7 years agoHelp with using I/O channels in OpenCL
I'm having issues using IO channels in OpenCL using the DE1SOC board from Terasic, I've modified the BSP and added in a basic LED controller to test it but still cannot make the LED l...
FawazJ_Altera
7 years agoHello,
Did you try hooking led_in to a direct switch and make sure rest of the circuit works fine and the LED lights up successfully?
Once you have confirmed this, how are you connecting the led_in[0] to the AVST intf generated by the compiler? Is it connect to the valid or the databus.
