Help with AOCL_LINK_CONFIG not finding OpenCL.lib
Hi, I could really use some help on this.
Preface: My target board is a Altera Terasic DE5-Net and I have successfully compiled a hello_world test from them through similar means. This leads me to believe that my Environment Variables, BSP, and OpenCL are setup and configured correctly. My host machine is running Windows 10 with version 19.1 of Quartus Standard.
Problem: I am attempting to make a Project with the attached Make File. Upon running make I get the following error.
g++: error: /libpath:C:/intelFPGA/19.1/hld/host/windows64/lib: No such file or directory
g++: error: OpenCL.lib: No such file or directory
make: *** [Makefile:169: run.exe] Error 1
My initial thought was that it couldn't find the directory or lib because of the appended /libpath: at the front of the location, but further reading into the documentation at https://www.intel.com/content/www/us/en/programmable/documentation/mwh1391807965224.html#ewa1411400813347 leads me to believe that it is correctly appending /libpath: to the front.
The OpenCL.lib file is at the location listed. In the Make File, I find that the actually setup for this command is at
LINK_CONFIG = $(shell aocl link-config )
and the call at
.PHONY: all
all: host fpga
.PHONY: host
host: $(HOST_EXE)
.PHONY: fpga
fpga: $(DEV_EXE)
$(HOST_EXE): $(HOST_OBJS)
$(CXX) $(OCV_LIBDIRS) $(OCV_INCLUDES) $(HOST_OBJS) -o $@ $(LINK_CONFIG) $(OCV_LIBS)
%.o: %.cpp
$(CXX) $(OCV_LIBDIRS) $(OCV_INCLUDES) $(CXXFLAGS) -c $< -o $@ $(COMP_CONFIG) $(OCV_LIBS)
$(DEV_EXE): $(KERNEL_SRCS)
$(OCC) $(OCCFLAGS) $< -o $@I will also paste the entire make file below. Any help is appreciated, thanks!
#set source and target for host
HOST_EXE = run.exe
HOST_SRCS = ./host/main.cpp ../common/ocl_util.cpp ../common/timer.cpp
HOST_OBJS = $(HOST_SRCS:%.cpp=%.o)
HOST_INCS = ../common
HOST_DEBUG = 1
#choose the BSP you would like to use
#BSP_DIR = /home/fpga/intelFPGA_pro/19.1/hld/board/a10_ref
#BSP_DIR = /home/fpga/intelFPGA_pro/19.3/hld/board/a10_ref
#BSP_DIR = /home/fpga/intelFPGA_pro/BSP/de5a_net_ddr4
BSP_DIR = C:\intelFPGA\19.1\hld\board\terasic\de5net
#BSP_DIR = /home/fpga/intelFPGA_pro/BSP/f10a_bsp_181/bsp_1801/f10a_remote_bsp
#if you are loading images from OpenCV interfaces please set to 1
USE_OPENCV = 0
#set source and target for device
#supported vendors are xilinx, altera, amd
VENDOR = altera
#select the host archecture x86|arm32
PLATFORM = x86
#optional flows are hw|hw_emu|sw_emu|report|profile|rtl|hw_sim
#hw -> generate hw for deployment
#hw_emu -> generate waveform for SDAccel
#sw_emu -> perform software emulation
#hw_sim -> co-sim with Modelsim for Intel OpenCL SDK
#report -> generate aoco and report(only for std version) for fast evaluation
#rtl -> generate aocr and report(only for pro version) for fast evaluation
#profile -> insert performance counters in fpga for dynamic profiling
#init -> initialization for incremental hw compilation with reduced time
#fast -> fast incremental compilation with reduced time
FLOW = rtl
#select which kernel file is used
ifeq ($(VENDOR),xilinx)
KERNEL_SRCS = ./device/conv_pipe_xilinx.cl
else
KERNEL_SRCS = ./device/conv_pipe.cl
endif
KERNEL_NAME = conv
KERNEL_DEFS =
KERNEL_INCS =
KERNEL_DEBUG = 1
#additional pragma for xilinx
CU_NUM = 1
MAX_MEM_PORT = 0
MEM_PORT_SIZE = 512
#select the device binary name
DEV_EXE = $(KERNEL_NAME).xclbin
else ifeq ($(VENDOR),altera)
ifeq ($(FLOW),report)
DEV_EXE = $(KERNEL_NAME).aoco
else ifeq ($(FLOW),rtl)
DEV_EXE = $(KERNEL_NAME).aocr
else
DEV_EXE = $(KERNEL_NAME).aocx
endif
else ifeq ($(VENDOR),amd)
DEV_EXE =
endif
#host compiler options
CROSS-COMPILE = arm-linux-gnueabihf-
ifeq ($(PLATFORM),x86)
CXX := g++
ifeq ($(USE_OPENCV),1)
#add your OpenCV PATH here
OCV_INCLUDES = C:\intelFPGA\19.1\hld\host\include
OCV_LIBDIRS = C:\intelFPGA\19.1\hld\host\windows64\lib
#for opencv_2.x
#OCV_LIBS = -lopencv_core -lopencv_imgproc -lopencv_highgui -lopencv_ml
#for opencv_3.x
OCV_LIBS = -lopencv_core -lopencv_imgcodecs -lopencv_imgproc -lopencv_highgui -lopencv_ml
endif
else ifeq ($(PLATFORM),arm32)
CXX := $(CROSS-COMPILE)g++
#add your cross compile OpenCV PATH here
OCV_INCLUDES = -I/usr/local/opencv-arm/include/
OCV_LIBDIRS = -L/usr/local/opencv-arm/lib
endif
endif
#select whether use OpenCV or not
CXXFLAGS = -g -Wall -std=c++11 -DUSE_OPENCV
else
endif
#select compile for sw_emu or hw (used verion >= 19.3)
ifeq ($(FLOW),sw_emu)
CXXFLAGS += -DSW_EMU
endif
COMP_CONFIG = -I$(XILINX_SDX)/runtime/include/1_2 -I$(HOST_INCS) -DFPGA_DEVICE -DXILINX
LINK_CONFIG = -L$(XILINX_SDX)/runtime/lib/x86_64 -lxilinxopencl
COMP_CONFIG = $(shell aocl compile-config ) -I$(HOST_INCS) -DFPGA_DEVICE -D_WIN32
DEV_EXE =
endif
#opencl compiler options
#xilinx
OCC = $(XILINX_SDX)/bin/xocc -DXILINX
OCCFLAGS = --platform xilinx:kcu1500:4ddr-xpr:4.0 -t $(FLOW) -O2 --kernel_frequency 200 --save-temps --report system \
--memory_port_data_width memWrite:32 \
--memory_port_data_width memRead:512 \
--nk memWrite:1 --nk coreConv:1 --nk lrn:1 --nk maxPool:1 --nk memRead:1 \
#memory optimization for xilinx
ifeq ($(MAX_MEM_PORT), 1)
OCCFLAGS += --max_memory_ports all
OCCFLAGS += --memory_port_data_width all:$(MEM_PORT_SIZE)
endif
#altera
OCC = aoc
OCCFLAGS = -v -report -march=emulator -emulator-channel-depth-model=strict -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
else ifeq ($(FLOW),hw)
OCCFLAGS = -v -report -seed=3 -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
else ifeq ($(FLOW),init)
OCCFLAGS = -v -report -seed=3 -incremental -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
else ifeq ($(FLOW),fast)
OCCFLAGS = -v -report -seed=3 -incremental -fast-compile -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
else ifeq ($(FLOW),profile)
OCCFLAGS = -v -report -profile -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
else ifeq ($(FLOW),report)
OCCFLAGS = -v -c -report -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
OCCFLAGS = -v -rtl -report -fmax=300 -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
else ifeq ($(FLOW),hw_sim)
OCCFLAGS = -v -report -march=simulator -ghdl -I device/RTL -L device/RTL -l rtl_lib.aoclib -board-package=$(BSP_DIR)
endif
# misc options for altera
# add support for arbitrary precision integers
OCCFLAGS += -I $(INTELFPGAOCLSDKROOT)/include/kernel_headers
#amd
OCC =
OCCFLAGS =
endif
#debug option
ifeq ($(KERNEL_DEBUG),1)
OCCFLAGS += -g
else
OCCFLAGS += -g0
endif
.PHONY: all
all: host fpga
.PHONY: host
host: $(HOST_EXE)
.PHONY: fpga
fpga: $(DEV_EXE)
%.o: %.cpp
.PHONY: run
run:
./run.exe $(KERNEL_NAME).aocx
.PHONY: log
log:
./run.exe $(KERNEL_NAME).aocx | tee >run.log
.PHONY: clean
clean:
rm -rf *.sof *.xclbin *.rpt *.sv *.efisim *.tmp *.temp *.txt *.json *.dir *.aocx *.aoco *.aocr *.source *.exe xocc* sdaccel* ./device/*.ll ./host/*.o ../common/*.o *.jou *.mon *.cl1 Reply
- AnilErinch_A_Intel
Hi
Please let us know , whether the suggestions in the below forum post helps you.
https://forums.intel.com/s/question/0D50P00003yyRHkSAM/build-issue-with-eds
Thanks and Regards
Anil
