HBM - high band memory
I tried to generate an HBM memory example module when my device is Stratix 10.
I have two projects:
One where the HBM is located at the top, and another where the HBM is located at the bottom.
Both projects are configured in the same way: only channel 0 (ch0) is used.
The project with the HBM located at the bottom works, and Quartus successfully completes all stages up to the "Generate Programming Files" stage.
However, the project with the HBM located at the top fails during the Plan stage, and I receive the following message:
Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 UFIND4H_UIB(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error(175001): The Fitter cannot place 1 UFIND4H_UIB, which is within High Bandwidth Memory (HBM2) Interface Intel FPGA IP ed_synth_hbm_0_example_design_altera_hbm_1961_juniqfi.
Info(14596): Information about the failing component(s):
Info(175028): The UFIND4H_UIB name(s): hbm_0_example_design|hbm_0_example_design|uib|arch_inst|ufi_inst|ufi_inst
Error(16234): No legal location could be found out of 1 considered location(s). Reasons why each location could not be used are summarized below:
Error(175006): There is no routing connectivity between source HBMC and the UFIND4H_UIB
Info(175026): Source: HBMC hbm_0_example_design|hbm_0_example_design|uib|arch_inst|hbmc_inst|hbmc_inst
Info(175021): The source HBMC was placed in location HBMC_X95_Y2_N1
Error(175022): The UFIND4H_UIB could not be placed in any location to satisfy its connectivity requirements
Info(175029): 1 location affected
Info(175029): UFIND4HUIB_X95_Y292_N0
Could you assist how can I solve it ?
- AdzimZM_Altera
Hi ymiler,
I have a few questions in points below:
- What is the device OPN that you used?
- Which Quartus version that you used?
- Are using example design that has been generated from the HBM2 IP?
- For example, this document has provided some guides to create the example design: https://www.intel.com/content/www/us/en/docs/programmable/683379/20-1-19-4-0/generating-the-synthesizable-high-bandwidth-15038.html
Adzim
- AdzimZM_Altera
Hi ymiller,
I think there are some missing files from your archive project that may cause the issue.
It's reporting there are conflict to constraint the design.
Can you start designing your project based on the design in the attachment?
This is the example design that can compile successfully.
Please check if you still see the failures with this design.
Adzim
- ymiler
Contributor
Hi Adzim,
Then, I tried to create example design from scratch again ( HBM location -top )
but still I got error:
Error(175001): The Fitter cannot place 1 UFIND4H_UIB, which is within High Bandwidth Memory (HBM2) Interface Intel FPGA IP ed_synth_hbm_0_example_design_altera_hbm_1961_g23n22y.
Info(175029): UFIND4HUIB_X95_Y292_N0Just want to remind that when the HBM location define in the Bottom everything works correctly
Do you have idea how can I solve it ?
- ymiler
Contributor
want to add to my previous post :
your archive project works fine and compile successfully in my workspace ,
but when I try to create from scratch example design ( HBM location -top ) still I get error
