Hi
good news!!
I found the root cause of the error :
Error(175001): The Fitter cannot place 1 UFIND4H_UIB, which is within High Bandwidth Memory (HBM2) Interface Intel FPGA IP ed_synth_hbm_0_example_design_altera_hbm_1961_g23n22y
It was my set_location_assignment pin clock to PIN_AR26 - when remove it the Quartus succeed to finish the Plan stage successfully
But , Why ? this is legal pin ?
In addition , when the HBM is located at the bottom there is no issue even the assignment of the PIN_AR26
Are there more problematic pins when the HBM locate at the top ?
