HardSigmoid and Intel FPGA AI suite
This is for the database generation and you are creating it to run in CP and FPGA (--foutput-format=open_vino_hetero). How do you confirm if the current AI Suite is able to run your model?
Hi @JohnT_Intel
I'm sorry, but currently, I'm trying to understand Intel FPGA AI Suite documentation, get used to the workflow, and apply it to my own neural network, so maybe I'm a little confused.
At this moment, I'm not able to confirm whether this model can be run in an Intel FPGA AI Suite IP core. In the examples provided in the "Intel FPGA AI Suite: Getting Started Guide" and "Intel FPGA AI Suite SoC Design Example User Guide," the "--foutput-format=open_vino_hetero" option is used, and the model is run in a prebuilt core. I know this option makes the model run on both the CPU and FPGA, but I understand that only non-supported layers are run on the CPU.
The question is, why does the H-sigmoid layer, which should be compatible with Intel FPGA AI Suite according to the "Intel FPGA AI Suite IP Reference Manual," seems to be executed on the CPU after compiling the graph?
