HAL Kernel Version Mismatch Error During FPGA Emulation with vector-add Sample
Hi @Pavithran11,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
The HAL version mismatch may be cause by the runtime or emulation environment not matching with compiled kernel metadata. Which sometime multiple oneAPI version could cause the mismatched.
Would suggest the following below:
- Check for only source one version of oneapi: source /opt/intel/oneapi/setvars.sh
- Manually source the matching BSP with some command as followed: export AOCL_BOARD_PACKAGE_ROOT=/opt/intel/oneapi/intelfpgadpcpp/2022.0.2/board/de10_agilex
- Just to confirm there is no duplicates BSP when running the aoc -list-boards right?
- Are you seeing this issue only in emulation (fpga_emu)?
Hope to hear from you soon.
Best Wishes
BB
